no oil pressure posted by jdavey11 on April 20, 2013 at 06:52 PM
Check the bottom of the pan for dents . A lot of replacement engines have been sat on the pan causing it to be pushed in against the oil pick up tube . This will restrict the oil from being picked up . If it is pushed in it can be addressed without pulling the engine . If the pan is fine did you prime the oil pump ? Check it with a second gauge / sending unit .
